Jul 24, 2021Guide
Blinking white and amber
I woke up in the morning and found that the router is not working. No device is connected. I checked the device I found that the routre power leds and eathernet connection leds are bliking alternativ...
Jul 25, 2021Guru - Experienced User
I'd start with trying to factory reset it. Push and hold reset for 7-15 seconds while powered on.
If that doesn't work, you can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
970222
Jul 25, 2021Guide
Hi,
Thanks a lot for your quick response. I tried many times to do a factory reset. Followed 30/30/30 and I was not able to reset.
Then, I tired tftp. I followed everyting that the youtube showed. However, the tftp failed with error saying unable to connect the device. Looks like I can't make the device to connect no matter what I do.
Is there any other suggestion?
Thanks in advance.
- plemansJul 25, 2021Guru - Experienced User
tftp is sensitive to timings. I'd try it a couple times at different times as theres a narrow window in which to execute.
I'd also try the nmrpflash. I've had success with that when tftp wouldn't work.
- 970222Jul 28, 2021Guide
Nothing works, I am about to accept this $200 box is now a piece of Brick and will throw it to trash. Unless anyone have any suggestion. Not buying any Netgear product anymore.
