wgd1350
Aug 20, 2017Aspirant
Block an external IP address in Netgear R9000-100NAS Nighthawk X-10
I had an intruder logged in from a local IP that is a Comcast Public WiFi. It is over a mile and a half away. I want to block their IP. I am not clear on how to do that. I did not get a MAC addre...
- Aug 20, 2017Just mark the thread solved.
TheEther
Aug 20, 2017Guru
Can you be more specific? What are they logged into? Your router? Your router's Wi-Fi? A machine on your home network?
Depending on your answer, the appropriate action will generally be to either disable remote management, UPnP or port forwarding.
