pmp6nl
Jun 14, 2017Aspirant
Block Device Access to Internet
I have searched, but I dont think I can find the info I am looking for. I have IP cameras on my network. I would like to prevent them from accessing the internet. How do I do that within the router? ...
- Jun 15, 2017
Hi pmp6nl,
You can try the block services.
Block the port number that the IP cameras uses to access Internet. (For example port 553 for HTTPs websites and 80 for HTTP).
Check under UPnP table if your camera is showing and check for the port numbers it uses.
https://kb.netgear.com/24306/How-do-I-enable-Universal-Plug-and-Play-on-my-Nighthawk-router
