pmp6nl
Jun 14, 2017Aspirant
Block Device Access to Internet
I have searched, but I dont think I can find the info I am looking for. I have IP cameras on my network. I would like to prevent them from accessing the internet. How do I do that within the router? ...
- Jun 15, 2017
Hi pmp6nl,
You can try the block services.
Block the port number that the IP cameras uses to access Internet. (For example port 553 for HTTPs websites and 80 for HTTP).
Check under UPnP table if your camera is showing and check for the port numbers it uses.
https://kb.netgear.com/24306/How-do-I-enable-Universal-Plug-and-Play-on-my-Nighthawk-router
pmp6nl
Hi JamesGL,
Yes that is exactly what I want. Thank you.
JamesGL
Jun 15, 2017NETGEAR Employee Retired
Hi pmp6nl,
- JamesGLJun 19, 2017NETGEAR Employee Retired
Hi pmp6nl,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- pmp6nlJun 19, 2017Aspirant
Hello,
Thanks. So I can use that function to select the ports I want to block and tell it to only block those ports on the camera by using the ip address function. But I assume there is no way for it to differentiate wan and lan? For example on the lan I want it to be able to access port 80, but I want that port blocked to wan. Does that make sense? Thanks
- pmp6nlJun 22, 2017Aspirant
Hello,
