jollygiant
Feb 01, 2022Guide
Block Schedule is out of Sync with NTP Clock
When I schedule a block for 12:01 am to 6 am, the router starts blocking at 7 pm. This feature used to work. My firmware is up to date with the latest. Did a firmware update cause the problem? Th...
Feb 01, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
jollygiant
Feb 01, 2022Guide
I'm not sure. Is a factory reset recommended? Wouldn't that install an earlier firmware version?
- FURRYe38Feb 01, 2022Guru - Experienced User
jollygiant wrote:
I'm not sure. Is a factory reset recommended? Wouldn't that install an earlier firmware version? No. Just wipes user configurations from the router.
- jollygiantFeb 02, 2022Guide
I did a factory reset and set up the clock and block schedule again, as suggested. At 11:15 pm I set the blocking to start at 1:30 am and to stop at 6 am. The blocking started immediately. Something is still wrong.
