Sa9aX11's avatar
Sa9aX11
Guide
Jun 19, 2016
Block Sites using wildcards
Hi   Can I use wildcards to block links that containts with the word "ads" (eg. ads.* , ads*.* , ads.*.*) ?   Sal
  • TheEther's avatar
    TheEther
    Jun 20, 2016
    It's an unwinnable battle to block ads on the router using hand-entered keywords.  To give you an idea of the enormity of the problem, consider the biggest filter list used by uBlock Origin (https://easylist.github.io/easylist/easylist.txt).  This list contains over 65,000 lines.
    How are you expecting ads to be seen other than through a browser?
