Acann
Sep 04, 2024Aspirant
Blocking a specific device on a Nighthawk X6
I am trying to block a specific device from connecting to my Nighthawk router. I can access the router by using 192.168.1.1 to log in. I can see the device I am trying to block. I went to advanced th...
Sep 04, 2024Guru - Experienced User
Do you have Circle or Smart Parental controls enabled in the Nighthawk app?
FW is behind.
