Acann
Sep 04, 2024Aspirant
Blocking a specific device on a Nighthawk X6
I am trying to block a specific device from connecting to my Nighthawk router. I can access the router by using 192.168.1.1 to log in. I can see the device I am trying to block. I went to advanced th...
Sep 04, 2024Guru - Experienced User
Do you have Circle or Smart Parental controls enabled in the Nighthawk app?
FW is behind.
Acann
I updated the firmware to V1.0.4.88_10.1.88.
I do not have acircle or smart parent.
I tried to access the specific devices after updating the firmware. I get the same emoji that says: 192.168.1.1 didn't send any data".
- FURRYe38Sep 04, 2024Guru - Experienced User
Try a factory reset and setup from scratch after FW was updated?
