rochem
Jan 19, 2022Aspirant
Blocking HotSpot Shield VPN
My teenage kids have figured out by installing HotSpot Shield VPN while on celluar data they can bypass Circle 1st gen on my Netgear RAX80 router. How do I block Iphone users from using HotSpot S...
Jan 20, 2022Guru - Experienced User
You'll play the game of "what vpn are they using now". Here's the details on blocking hotspot shield but you'll have to search each vpn's specifics to block those.
What a quick internet search returned about blocking Hotspot Shield and what you want to achieve is:
Block the following TCP and UDP ports outbound:
11948040-80458245
Make sure the following domains are blocked:
hotspotshield.comhotspotshield.netanchorfree.comanchorfree.netopenvpn.net
rochem
Jan 20, 2022Aspirant
Thank you, I will give this a try.
