TomBlack's avatar
Sep 03, 2017
blocking site?
Running the latest Firmware!
The Log File does not show Blocked Sites activity.  My WNR3500 did show Blocked Sites in the Log File.  Not having this info makes it harder to see what's going on, if Blocked Sites is working and better allow the user to manage the router.
Blocked Sites are being sent out via email, but also need it in the log file.
All of my log settings are turned on.
  • Try to reinstall the firmware and then do a factory reset.
    Mine seems to show all sites I visited.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, TomBlack
    What sites are you accessing? Are these HTTP or HTTPS sites? What's the exact firmware version installed on your router?
    • TomBlack's avatar
      TomBlack
      Guide
      Firmware Version
      V1.0.9.6_1.2.19
      Believe they are HTTP sites.
      Some Blocked Site are appearing in my logs, but it does seem like I get more email notifications of Blocked Sites than acctually appear in the log.
      • ElaineM's avatar
        ElaineM
