222Graham222
Sep 17, 2021Guide
Blocking sites allowing more than 1 trusted IP
I need to block certain sites during selected hours but need more than one trusted IP to be able to bypass the blocks I put in place. Seems pretty crazy that I can't add more than one trusted IP. I...
Sep 17, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle and know how to work it better than those of us who follow this "Nighthawk WiFi Routers" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Good Luck
222Graham222
Sep 17, 2021Guide
I'm aware of how to operate circle and it's not possible to achieve what I desire with that product, it's good but I can't really use it as a timer for the activities I want to block: they need to use both phones and computers normally to study for their lessons but they are children and very easily distracted so I want to stop them using trivial social media and youtube during their school periods.
For this I have to block either certain sites or by keyword but everyone else requires normal access for business so they can make a $$ during the day.
Thanks for the input, appreciated but unfortunately not relevant for this problem.
- FURRYe38Sep 17, 2021Guru - Experienced User
Something to post about in the Circle forum as that would get more visibility for the product your referring too.
Good Luck.
- 222Graham222Sep 19, 2021Guide
Thanks that's a great idea!
When I get a chance I'll post it their, but to my understanding Circle are giving up and going away really soon, well from Netgear and (circle) they don't support the router, you have to go through Netgear for that and some of the functionality doesn't work, like the backup feature, so if it goes wrong you have start all over again... it's not as good as you'd think anymore :smileysad:
- FURRYe38Sep 19, 2021Guru - Experienced User
Some routers are being migrated to SPC:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controlsWhich still use Circle app for its mobile UI interface.
