222Graham222
Sep 17, 2021Guide
Blocking sites allowing more than 1 trusted IP
I need to block certain sites during selected hours but need more than one trusted IP to be able to bypass the blocks I put in place. Seems pretty crazy that I can't add more than one trusted IP. I...
222Graham222
Sep 19, 2021Guide
Thanks that's a great idea!
When I get a chance I'll post it their, but to my understanding Circle are giving up and going away really soon, well from Netgear and (circle) they don't support the router, you have to go through Netgear for that and some of the functionality doesn't work, like the backup feature, so if it goes wrong you have start all over again... it's not as good as you'd think anymore :smileysad:
Sep 19, 2021Guru - Experienced User
Some routers are being migrated to SPC:
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Which still use Circle app for its mobile UI interface.
