Activity61
Nov 08, 2016Follower
Bonded MoCA 2.0
Hi @All Is the standard "bonded MoCA 2.0" supported by the Netgear nighthawk ac 1900 dual band wifi router? Thanks for the answer. Regards HJ
- Nov 10, 2016
Hi Activity61,
If there is no other configuration that needs to be done on the MoCA 2.0 device then it should be able to work with the R7000. As long as is provides internet connection then the router should be able to work.
JamesGL
Community Team
JamesGL
Nov 10, 2016NETGEAR Employee Retired
Hi Activity61,
JamesGL
Community Team
- PJS-TexNov 11, 2016Aspirant
I am looking to purchase a MoCA adapter. On the listing for the adapter, it states in the desription that:
"Requires that your router support bonded MoCA 2.0"
Does the router support it?
Th listing is below for the Moca adapter
- TheEtherNov 11, 2016Guru
I believe you can ignore that requirement. As far as the router is concerned, the MoCA adapter will look like an Ethernet cable.
