Activity61
Nov 08, 2016Follower
Bonded MoCA 2.0
Hi @All Is the standard "bonded MoCA 2.0" supported by the Netgear nighthawk ac 1900 dual band wifi router? Thanks for the answer. Regards HJ
- Nov 10, 2016
Hi Activity61,
If there is no other configuration that needs to be done on the MoCA 2.0 device then it should be able to work with the R7000. As long as is provides internet connection then the router should be able to work.
JamesGL
Community Team
