tester2011
Mar 02, 2021Guide
Bought a used r8500..having issues setting it up
I purchased a used a R8500 today and went onto set it up. Put my Rogers modem into bridge mode and then went onto setup the router. I factory rested the fouter in case the other persons setting was s...
tester2011
Mar 03, 2021Guide
Haven't tried..but is that even possible?
shadowsports
Mar 03, 2021Hero
Greetings,
Yes. The router is capable of operating independently.
If it doesn't have an internet connection avaialble, you can still log into it to change or modify its settings.
- tester2011Mar 03, 2021GuideI'll give that a try. Is it not normal for it to have the wifi go on and off every minute and also drop a hardwired connection every minute and then reconnect? Or is it because it's not set up?
- shadowsportsMar 04, 2021Hero
Posted to the wrong thread. Please ignore this post.
