tester2011
Mar 03, 2021Guide
Bought a used r8500..having issues setting it up
I purchased a used a R8500 today and went onto set it up. Put my Rogers modem into bridge mode and then went onto setup the router. I factory rested the fouter in case the other persons setting was s...
tester2011
Mar 04, 2021Guide
The power led is AMBER.
The other thing is I contacted Netgear support and they need the reciept for the unit for the warranty. The warranty is valid until next year of March. But I have no way of obatining a receipt or contacting the seller as he deleted hsi facebook account after selling me the unit.
This is what the warranty page shows me:
Product: R8500 Serial Number: ************ Country of Purchase: Canada Puchased on: 2021-02-26 Registered on: 2021-02-26
Standard Product Warranty * Hardware Warranty: Available till 2022-02-26 Chat Support: Available till 2021-05-27 Phone Support: Available till 2021-05-27 Email Support: Available till 2021-05-27 Power Supply Warranty: Available till 2022-02-26 Accessories Warranty: Available till 2022-02-26
michaelkenward
Mar 05, 2021Guru - Experienced User
The thing is bust.
You were sold a pup.
Warranties are not transferable.
You either put it down to experience and write off the purchase, or persevere with TFTP.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to tell Windows to use TFTP on your PC.
TFTP isn't the easiest operation, so if you are forced to use it you could try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
- tester2011Mar 12, 2021Guide
TFTP did not do the job so I will be resorting to the USB_TTL cable method. Netgear support has been no help. There was wwarranty on the unit and the correspindant who emailed me decided to ask me for a photo of the serial number in order to transfer the unit to me and then at the same time ceasing the warranty after transfer. I've emailed them back and no response, been 3 days.
Never buying a Netgear again!
- michaelkenwardMar 12, 2021Guru - Experienced User
I'm surprised they even offered. Warranties don't usually transfer.
You bought used. Heaven only knows what damage the original owner had done to the thing. Maybe that's why they sold it.
- tester2011Mar 15, 2021Guide
Having tried numerous steps to resolve the issue my router is now stuck on solid white. Power LED is white and another 4 LEDS. I have removed the board from the case.
Is it looking good for me? Before it was just AMBER power led light and would reboot. - michaelkenwardMar 15, 2021Guru - Experienced User
Looks OK, although, not knowing what those other four LEDs are, no guarantees.
