Suncatchers
Nov 12, 2020Aspirant
Bought new nighthawk ac1750 router. Cant get it to connect with my arris sb6183 modem
Tried set up through the app. Says it can't recognize the router. When I check for the network on my cell phone it doesn't show up. When I reconnect my old router (not netgear) to my modem I have no p...
Nov 12, 2020Guru - Experienced User
What router do you have? AC1750 is a speed, not a model.
Try installing it with a pc/laptop. You can hardwire into it for setup.
power off both the modem and the router. disconnect coax from the modem.
connect coax back to modem. power it on. give it several minutes.
connect lan cable from modem to wan port on router.
power the router on. give it several minutes.
then try the setup using a pc/laptop.
to get the install guides. go to netgear.com/support/ type in your actual modem number and it'll take you to guides, firmware, manuals.
- SuncatchersNov 12, 2020AspirantThe model is R6350. I don't have a computer. Only cell phones and a smart tv. So unfortunately that isn't an option. Thank you.
- plemansNov 12, 2020Guru - Experienced User
You can install it using the browser on your phone
