Suncatchers
Nov 12, 2020Aspirant
Bought new nighthawk ac1750 router. Cant get it to connect with my arris sb6183 modem
Tried set up through the app. Says it can't recognize the router. When I check for the network on my cell phone it doesn't show up. When I reconnect my old router (not netgear) to my modem I have no p...
Suncatchers
The model is R6350. I don't have a computer. Only cell phones and a smart tv. So unfortunately that isn't an option. Thank you.
Nov 12, 2020Guru - Experienced User
You can install it using the browser on your phone
