AbsolutZeroGI
Sep 22, 2019Aspirant
Brand new R8000 having speed issues
Hello, long time Netgear user, first time caller in the forums. I recently purchased an R8000 AC3200 to replace my aging (and dying) Nighthawk AC1900. For a good 4-5 days I had no problems at al...
- Sep 23, 2019
AbsolutZeroGI wrote:Firmware: V1.0.4.46_10.1.63
When I click "check for update", it says there are no updates.
BAD BAD F/W that does cause problems.
You probably had V1.0.4.28 on the router when you bought it, but it also had AUTO-UPDATE enabled... and when that happened, you had the problem.
I suggest to log into Support at top, enter R8000 and select DOWNLOADS, then open PRIOR VERSIONS (+) and get selected V1.0.4.28. Click on the README for details on how to install the f/w. When told you are installing an older version do OK. Once the router reboots, TURN OF AUTO-UPDATE. Maybe the next f/w release might work, so keep checking here or on the Support tab to see if/when it is released.
AbsolutZeroGI
IrvSp
Sep 23, 2019Master
