SoullessWolfy
Jun 18, 2021Follower
Bricked a R6120 Router during update
While updating with the Nighthawk app, my phone had a short service outage, and disconnected from my router while updating. It now only displays a flashing power light. When I connect it to my P...
michaelkenward
Jun 19, 2021Guru - Experienced User
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
It is important to follow the steps exactly and to pay attention to the messages you see.
It can take several attempts to get it right.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
