iRenaissanceMan
Jan 19, 2020Aspirant
Bricked R8500 unable to get to CFE
Hi, I've been trying to resurrect my bricked R8500. I've read most of the forum material on bricked R8500 and followed peter11742's journey. https://community.netgear.com/t5/Nighthawk-WiFi-Route...
- Jan 20, 2020
Yes you need to have the USB cable plugged in and terminal active when you start the router up as the CFE comes right after the power up. If you are plugging in after you start the router then you will miss the CFE unless very lucky. I suspect, as I said earlier, you have a defective USB serial cable. Have had similar issues with bad ones. They are CHEAP and do not hold up well and had one that was defective out of the box.
Best I can do for you at this point is to wish you good luck.
labatt
Jan 20, 2020Mentor
Time I had trouble with things working correctly with the USB serial cable it turned out to be the cable bad. Even though it seemed to almost work. I assume you are only connecting the two data connections and the ground? Do not connect the +3 volt or what ever it is called connection. You have to watch and react fast to get into the CFE. Have done this process many times over the years.
labatt
Jan 20, 2020Mentor
Above should say not working correctly. Netgear, in their infinite wisdom removed the edit function.
