BillKearns
Oct 15, 2020Aspirant
BRIDGE A C7100V MODEM/Router C7100V TO A NIGHTHAWK AC3600
Last December, I purchased a Nighthawk cable modem C7100v and just replaced it with a Nighthawk cable Modem CM1150v. Along with the CM1150v I installed a Nighthawk x65 AC3600 router. My question is...
- Oct 15, 2020
Since the AC1700 no longer activated (as a working modem) it wouldn't work as an access point. Correct?
BillKearns
antinode
Oct 15, 2020Guru
What's an "AC1700"? Assuming that you mean the C7100V, why not? You
wouldn't be using its modem section, only (parts of) its router section.
Who would need to "activate" what?
The whole point of that cited thread was to explain how to configure
a Cxxxx modem+router as a WAP. Why would I cite it (or write the
procedure in it) if I believed that that task was impossible?
