blshaw45's avatar
blshaw45
Bridge mode disables radios
I am trying to help a neighbor with a significant WiFi problem. He is totally unfamilar with the technology while I have a little bit more experience but, apparently, not enough.   In his residnce ...
  • antinode's avatar
    Aug 24, 2020
       What, exactly, does "Bridge mode" mean to you?  This term is greatly
    over-/mis-used, leading to many misunderstandings.
    > [...] as soon as I set Router Mode to 'off' and the device reboots,
    > the radios are turned oiff and can't be turned back on.
       Right.  If you're looking at "Cable Your Modem Router to a Router and
    Use Bridge Mode" in the C7000 User Manual, then setting ADVANCED >
    Administration > Router Mode to "Off" means disabling the router
    entirely, leaving only the modem (in "bridge mode", meaning about as
    stupid as a piece of wire).  No routing, no radios, only an Ethernet
    port which you can connect to a real router (or a single
    computer/device).  Not what you want.
    > [...] connect it back to the primary router via Ethernet (we can get a
    > CAT-5/6 cable between the two buildings).
       If you leave out the "bridge mode" description, then what you really
    want is a wireless access point (WAP).  The C7000 does not formally
    offer a WAP mode, but almost any router can be configured as a WAP,
    including a C7000.  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a Netgear C6300-as-WAP, but the steps are about the
    same for any other router (any make/model) which lacks a one-step WAP
    option.
