wotgr7000
Mar 07, 2019Aspirant
Bridge mode does not work via 5G
I have 2 R7000, both are working fine when configured as Router. 2.4G and 5G wifi work flawlessly in router mode. Both running firmware 1.09.42.
When I configured one of them as a Bridge, the...
- Mar 08, 2019
Working on the basis that in this context bridge mode is WDS, have you been through the appropriate section in the manual?
>>>> R7000 | Product | Support | NETGEAR <<<<
See the section Set Up a Wireless Distribution System. You may have done this, but knowing that Netgear doesn't hand out manuals these days, I thought it worth mentioning.
michaelkenward
Mar 08, 2019Guru - Experienced User
- wotgr7000Mar 14, 2019Aspirant
Thanks for you advice. Indeed I missed the option of choosing the wifi band. Problem solve.:smileyhappy:
