wotgr7000's avatar
wotgr7000
Bridge mode does not work via 5G
I have 2 R7000, both are working fine when configured as Router.  2.4G and 5G wifi work flawlessly in router mode.  Both running firmware 1.09.42.   When I configured one of them as a Bridge, the...
  • michaelkenward's avatar
    Mar 08, 2019
    Working on the basis that in this context bridge mode is WDS, have you been through the appropriate section in the manual?
    >>>> R7000 | Product | Support | NETGEAR <<<<
    See the section Set Up a Wireless Distribution System. You may have done this, but knowing that Netgear doesn't hand out manuals these days, I thought it worth mentioning.
