rclures1
Mar 21, 2022Aspirant
Bridge mode How to create
Trying to bridge a second nighthawk to my main nighthawk router. In all of the setup guides I read not one mentioned when and where to plug second router to. Right now I have a cable connection fr...
Mar 21, 2022Guru - Experienced User
What Nighthawk router do you have?
https://kb.netgear.com/25599/How-do-I-set-up-my-Nighthawk-X4-to-Bridge-mode
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
rclures1
A) Main router r6900v2
B) Bridge router r6700v3
If I understand bridging I will be connecting B to A in bridge mode??
- FURRYe38Mar 22, 2022Guru - Experienced User
Correct. with the A router already setup, just configure the B router in bridge mode for A routers SSID name and PW.
- rclures1Mar 22, 2022Aspirant
So how do I access B router? With my hard wire from A router? If so would I not access A routers setup?
I think I got it wireless right but how do I get to router B to setup? Cause Ive had B hard wired to A try to login goes to router A.
What am I missing? Thanks for the help!!
