keithamason
Jun 23, 2021Guide
Bridge Mode on AC1600 Model R6330
I'm trying to configure the AC1600 Model R6330 for bridge mode. The manual indicates you go to ADVNACED > Advanced Setup > Rounter/AP/Bridge Mode. However this is NO "Rounter/AP/Bridge Mode". T...
- Jun 24, 2021
On the page you linked to, click on "use other operation mode" then "enable bridge mode"
antinode
Jun 23, 2021Guru
> [...] R6330 [...]
> Model: R6300|Dual Band 11ac WiFi Router R6300
Which is it? Firmware version?
> [...] The manual indicates you go to ADVNACED > Advanced Setup >
What _did_ you find there?
> The manual doesn't have ANY screen shots, [...]
Neither does your complaint.
Are you looking at ADVANCED > Setup or ADVANCED > Advanced Setup ?
