RealTurokB
Nov 10, 2021Follower
Bridge Mode Sharing Issues
Weird Issue im having. I have a Router/Modem Combo from ISP (Primary Router) I needed to attach some network devices that dont have wireless from a distance so i added an R7000 (Secondary Router) in ...
Nov 11, 2021Guru - Experienced User
When in bridge mode, the R7000 works just as a wireless client so all data just passes thru the R7000 in this mode. There should not be any kind of data manipulation in this mode. So you won't see any additional features and user configurations like you would in Router mode. There is no need since the data is just flowing thru the antennas and to the LAN ports.
Make sure you are connected to the LAN ports and not the WAN port. I don't believe the WAN port is usable in Wireless Bridge mode.
