Jellikit
Nov 08, 2022Guide
Bridge mode?
I have a primary router in my house, where the internet comes in. From there, I have a cat 6 cable running from the primary router, to a secondary router (about 100’) out into my garage/guest house. W...
Nov 09, 2022Guru - Experienced User
sonos are sensitive to double nats. Try the AP mode. It fixes the double nat and has worked well when I've used it with my couple sonos devices.
Jellikit
Nov 09, 2022Guide
Do I want the two routers to have the same SSID? Or different? Thanks.
- plemansNov 09, 2022Guru - Experienced User
Depends on what you're trying to do and how much their wireless overlaps.
If it overlaps to much, devices might not roam between the 2 if you use the same ssid.
But you can always try setting the broadcast power down a bit.
Or you can use separate ssid's and just manually switch over.
