Kelszxr's avatar
Kelszxr
Bridge x4s to Telstra nbn
Hi I would like to know if it is possible to either bridge to the Telstra router or have the VoIP go to my x4s nighthawk as the reason I bought this router was because it stated nbn ready but I can't...
  • mondenath's avatar
    mondenath
    Jul 24, 2017
    Are you talking aboute voip phone . ADSL port can run a phone . I believe those are for internet connections.
    yes certain modem have VOIP built in modem. As they are voip dedicated port.
    No i am afraid netgear ever have produced such a router / modem yet.
    As there is alternative of this model x7800 i believe that comes with Adsl / RJ11 port for dial up of adsl for internet only.
    For Voip or phone you still have to use the old modem. Just used this router for Internet and disable any wifi in old modem/router.
    You should be good to go.
