Photosphere's avatar
Oct 15, 2019
Bridged network
I am using windows on a mac computer.  I would like to use the windows brdiged network adapter setting.  However, when I do that I lose wifi connectivity on the mac side. From whtat I have been able ...
  • Photosphere's avatar
    Photosphere
    Oct 15, 2019
    I have found the solution to my problem.  It wasn't an issue with the router.
    For those who may be seeking a solution to this problem, here it is:
    -Open the Windows confguration window
    -Click on Network
    -Click on advanced settings
    -Change DHCP from "use Host MAC address" to "use generated MAC address"
