bobbydigital00
Oct 10, 2022Apprentice
Bridging to wireless routers together on separate networks
Hello World, I am trying to solve a speed low signal problem I have in my basement. I have fiber gig speed in my home and I have some devices connected in my basement. Because of the speed and ...
- Oct 11, 2022
No.
bobbydigital00
Oct 11, 2022Apprentice
Thanks for all responses.
I have another question. In reviewing the Orbi devices. I see they have an Ethernet port output on the back of them.
If I am using the Orbi device to pair with my wireless router could I leverage the Ethernet port on the Orbi and connect to a switch to allow wired connectivity to devices that do not have wifi?
Update - I believe the Orbi is a wireless router itself and then I purchase the satellites. I could not pair the Orbi satellites with my Nighthawk router. Please confirm if this is true.
Oct 11, 2022Guru - Experienced User
Orbi satellites only pair and sync with Orbi routers.
- bobbydigital00Oct 11, 2022Apprentice
so could I use something like this - https://www.netgear.com/home/online-gaming/routers/xrm570/
Put the extender in the basement and connect the ethernet port to a switch, would this setup work?
- FURRYe38Oct 11, 2022Guru - Experienced User
That is a EX7700 extender that comes with the XR series router. The extender when connected to ethernet would be in AP mode and would not be on a separate network. If you connected the XR router in the basement and configured it for router mode, then you would have wifi signal and be on a separate network.
Got it.
So lets say I keep my old router on 172.16.x.x
purchase a new router with an extender that has an Ethernet port. The new router would be lets say 192.168.x.x and I put the extender in the basement and connect the ethernet port on the extender to my switch in the basement would this setup work?
