bobbydigital00
Oct 10, 2022Apprentice
Bridging to wireless routers together on separate networks
Hello World, I am trying to solve a speed low signal problem I have in my basement. I have fiber gig speed in my home and I have some devices connected in my basement. Because of the speed and ...
- Oct 11, 2022
No.
Oct 11, 2022Guru - Experienced User
As long as the extender is ethernet connected to the XR router for separate network, yes.
bobbydigital00
Oct 11, 2022Apprentice
Then it wont work. The Router will be upstairs and the Extender will be in the basement. I would have to connect the Extender using wireless. So basically I can't do both. I can't have the extender connected to the router wirelessly and then an Ethernet port from the Extender connected to a switch....
- FURRYe38Oct 11, 2022Guru - Experienced User
No.
- bobbydigital00Oct 11, 2022Apprentice
Is there any setup that would accomplish this other than running cable down to the basement?
