bobbydigital00
Oct 10, 2022Apprentice
Bridging to wireless routers together on separate networks
Hello World, I am trying to solve a speed low signal problem I have in my basement. I have fiber gig speed in my home and I have some devices connected in my basement. Because of the speed and ...
- Oct 11, 2022
No.
bobbydigital00
Oct 11, 2022Apprentice
Then it wont work. The Router will be upstairs and the Extender will be in the basement. I would have to connect the Extender using wireless. So basically I can't do both. I can't have the extender connected to the router wirelessly and then an Ethernet port from the Extender connected to a switch....
Oct 11, 2022Guru - Experienced User
No.
- bobbydigital00Oct 11, 2022Apprentice
Is there any setup that would accomplish this other than running cable down to the basement?
