uwillownnothing
Mar 25, 2022Aspirant
Bring back Ethernet management to your Nighthawk routers
Firmware version: 1.0.4.126(latest) Network environment: Netgear CM700 -> Netgear R6700v3 WAN port-> Windows PC(tried connecting Ethernet ports 1-4 and wireless individually) I preemptively adju...
michaelkenward
Mar 26, 2022Guru - Experienced User
uwillownnothing wrote:
I preemptively adjusted the settings to how I need them prior to attaching to the modem. VIA ETHERNET. I can access each setting in the webpage.
The moment I attached this router to an internet connected network I can no longer access the the web management page via Ethernet.
Meaning?
You can set up a router "off line" using an Ethernet connection, but after you have done that you need to start your network in the right way. You can't just plug things in willy nilly.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- dogweatherJul 09, 2022Initiate
I have the same issue with my Nighthawk R7000P and found this workaround: On ethernet, just connect to the router's IP address. E.g., for me it's:
Amazingly, doing it that way does not redirect to that site, and simply goes to the Basic Auth login and then the web admin UI.
