Fognet
Mar 09, 2022Aspirant
Brother HP-1440 will not USB to R7000P
I have followed all instructions. I cannot get my HP-1440 to connect to routers USB port. the USB light will not come on. The port works with other USB devices. And yes I have followed the manual. ...
Mar 09, 2022Guru - Experienced User
Holy cow. I was looking up manuals for that device and everything i found (brief search) was in french so it was a bit challenging to find much.
But what I did find says that was released in 2000 and was for windows 95/98/2000.
It still has a serial port on it.
I'm not sure if you could get that working as for the printer utility to work, it has to have a driver installed on the pc you're using.
Not sure if your pc has those OS's installed or if the printer utility even works on them.
https://www.brother-usa.com/support/hl1440
Its probably time to update the laser printer. Most decent ones have an ethernet port on them that tends to work a lot better.
- FognetMar 09, 2022Aspirant
Thanks I am using windows 11 pro. Also, unfortunately the drivers are imbedded in the printer. You are most likely right, I may have to replace it. Hate to, because the printer works great and ink lasts forever.
