Fognet
Mar 09, 2022Aspirant
Brother HP-1440 will not USB to R7000P
I have followed all instructions. I cannot get my HP-1440 to connect to routers USB port. the USB light will not come on. The port works with other USB devices. And yes I have followed the manual. ...
Fognet
Thanks I am using windows 11 pro. Also, unfortunately the drivers are imbedded in the printer. You are most likely right, I may have to replace it. Hate to, because the printer works great and ink lasts forever.
