Chacej
Nov 17, 2017Follower
Brother MFC-L24740DW doesn't recognize WPA (AES)
Hi, My Brother printer used to connect to my wifi over WPA (AES) and worked fine. I updated my router firmware to version 1.0.3.54_1.1.37 and the router now says no new firmware available. Since the...
- Nov 22, 2017
Hi Chacej,
Try to reset the router and reconfigure it manually.If you use TKIP, will it work?
