juliedon
Nov 04, 2015Aspirant
BT Vision channels compatibility with Nighthawk modem router D7000
Hi guys I've just ditched my BT hub 3 and bought the nighthawk D7000 Vdsl router. Everything set up fine but I can't get the BT you view channels to work. I've been told by netgear online chat ...
- Nov 07, 2015
OK, since you have those BT channels working now does that mean that you have no remaining issues?
juliedon
Nov 07, 2015Aspirant
Hi, thanks for the new firmware advice. I haven't done the firmware update, I got the BT vision channels working by doing a full reset on the Youview box. The channels are now coming through. The firmware version the netgear is using is 1.0.0.18. I did try to upload the 1.0.0.34 but it just says it's an img. file, although I have unzipped it and the file is a chk. file?
Babylon5
Nov 07, 2015NETGEAR Employee Retired
Are you saying that the router rejects the firmware upload?
- juliedonNov 07, 2015Aspirant
Yes
