Gizzard
Jul 24, 2015Star
BT Vision (UK IPTV / Internet) - Multicast + Unicast on same wired port??
Hi, I recently bought a Nighthawk R8000 to replace my BT Home Hub 4. All went well until I checked the BT Vision service I have. This box uses standard internet and multicast for TV services. ...
- Jul 11, 2016
Hello All,
Here's a trial firmware that you may try to get it working.
NGEddie
Jan 11, 2016Aspirant
Just wanted to add that my Netgear Nighthawk x4s (d7800) router/modem received a firmware upgrade lastnight (1.0.0.46) - in the firmware notes it mentioned that it was a fix for UK iptv issues specifically BT/plus net.
After installing the firmware I can confirm that I now receive BT sport channels directly and without any issues (though I have only just done the firmware so we will see in the long term). I didn't need to change any settings, it just worked after the router reboot.
Whether this is true for all nighthawk router/modems I don't know, but definitely for the D7800.
Snowmatt
Jan 11, 2016Tutor
Yes, the r7000 has also received an update and one of the features is bt tv support and all is working well now.
