Gizzard
Jul 24, 2015Star
BT Vision (UK IPTV / Internet) - Multicast + Unicast on same wired port??
Hi, I recently bought a Nighthawk R8000 to replace my BT Home Hub 4. All went well until I checked the BT Vision service I have. This box uses standard internet and multicast for TV services. ...
- Jul 11, 2016
Hello All,
Here's a trial firmware that you may try to get it working.
Gizzard
Jun 14, 2016Star
Hi Elaine,
Any update on this??? It appears that a fix for BT IPTV has been rolled out on other nighthawk routers but not the R8000.... I'm seriously doubting if it was wise buying the then "flagship" router if its being unsupported.
Thanks,
Wayne.
neilpatdrink
Jun 14, 2016Initiate
Also looking for an update on this thank you.
