Gizzard
Jul 24, 2015Star
BT Vision (UK IPTV / Internet) - Multicast + Unicast on same wired port??
Hi, I recently bought a Nighthawk R8000 to replace my BT Home Hub 4. All went well until I checked the BT Vision service I have. This box uses standard internet and multicast for TV services. ...
- Jul 11, 2016
Hello All,
Here's a trial firmware that you may try to get it working.
Gizzard
Aug 01, 2015Star
Hi Elaine... knowing my top of the range netgear can do what my old BT Home hub can do is very disappointing. Do you have an ETA for this feature?
Thanks Wayne.
Thanks Wayne.
Snowmatt
Aug 03, 2015Tutor
I agree with this. My router is an R7000, but having the same issue. These routers are high end and an such should have high end support. BT vision has been available for some time, so there should have been plenty of time the nighthawk routers to be updated to work as replacement for the stock routers.
