dav0dav0
May 03, 2021Guide
[Bug Report] R7000P Readyshare disconnects drive every few days
Running V1.3.2.134_10.1.66 firmware, connecting a 2 TB WD HDD with USB 3 to front connector of router. Drive has about 1.25 M files on it, in a single file system that's an MBR partition. At power ...
- Jul 04, 2021
After many weeks of experimenting with different drives, controllers, and file system contents, discovered one of the culprits: the DLNA option. This is on by default, and can be turned off by going to Advanced>USB Functions>ReadyShare Storage and going to the Media Server tab.
Evidently the DLNA service creates a nice little SQLite database of all eligible media files, and in one of my drives I have about 100,000 image files, 500 movies, and 20,000 audio files. This media mix caused that database to grow to more than 45 MB, which is evidently large enough to send the router into a tailspin within a couple of days. During that tailspin, it first won't let you log in to the administrative console, then it refuses new wifi connections, and finally it stops serving network traffic altogether.
When I turned DLNA off, the router still misbehaves, but in a less catastrophic way and only needs to be rebooted every 10 days or so.
Details: drive has two partitions, both NTFS.
dav0dav0
Jul 04, 2021Guide
