hydrasport
Feb 02, 2021Aspirant
Burned out Ethernet Port
My modem/router has 4 ports on the back. One port is dead. I need to plug 4 devices into the router. Two of the devices are security cameras that will not be used online very often and not at the sam...
- Feb 02, 2021
I wouldn't use an "adapter".
I'd buy a simple gigabit switch.
A 5-8 port one is usually around $20-30
Feb 02, 2021Guru - Experienced User
hydrasport
I found this splitter but I think you are correct about needing a switch. This only allows one input at a time. The cameras would both be trying to "input" at the same time. RJ45 Ethernet Splitter Cable, Rellyuar RJ45 1 Male to 3 X Female Port LAN Ethernet Network Splitter Adapter Cable Suitable Super Cat5, Cat5e, Cat6, Cat7 LAN Ethernet Socket Connector Adapter
