James_Brooke
Aug 21, 2022Aspirant
buying a router for use as vpn server while abroad
Hi all, I spend alot of time abroad and wish to buy a netgear router ? Nighthawk to access the regional content from my home internet connection while abroad. My current router is virginmedia...
Kitsap
Aug 21, 2022Master
James_Brooke, I am not sure michaelkenward fully understood your question.
I will take a run at it.
As I understand, you want to buy an Open VPN server capable router to connect to your Home Hub 4 gateway in the UK. You would need to configure your Home Hub 4 gateway to modem only mode, connect the new router, and configure the Open VPN server feature on your new router. The Open VPN server would be accessible from the internet. This access would be available from down the block or across the channel. You would configure the Open VPN server to allow outside access to both your LAN and the internet service available to your LAN. Sounds complicated, but you bite it off a chunk at a time and you can get there.
One of the bottlenecks you are going to quickly run into is the download/upload capacity of your internet service at the location of the router with the Open VPN server. You did not say anything about the capacity of the service you purchase. For talking purposes, say your download capacity is 250 Mbps and your upload capacity it 20 Mbps. When configured properly, your Open VPN server will take internet data from the downstream pipe (250 Mbps) and transmit an encrypted data stream out the upstream pipe (20 Mbps). This encrypted data stream is the one you connect to remotely from your device with the Open VPN client installed. It is very easy to saturate your 20 Mbps upstream pipe if you are transmitting video.
The installations I am familiar with used consumer grade equipment and provided reasonable access back to the US mainland from Mexico, Hawaii, or Canada. I found access from Japan or Midway to be problematic.
Another issue to consider is whether the location in the UK is unattended. I found it very helpful to have someone at home who I could call and ask them to please go in and restart the modem and the router.
In theory the answer to your question is yes. It will take some effort and learning on your part. There may be some technical hurdles in the UK I am not familiar with.
- James_BrookeAug 22, 2022Aspirant
Thankyou guys for your responses.
Luckily I have the fastest package (download 1132mb/upload 52mbs) so I am hoping that will be fast enough to stream the sports package!
I have ordered an r8000 and will get back to you all if I get stuck.
Thanks once again
- KitsapAug 22, 2022Master
Good to hear. When you get your new R8000, you will want to get your LAN configured and fully functional from home. Then tackle the VPN part.
