Kingquake
Jul 06, 2021Aspirant
C3000 Ooma phone service keeps disconnecting
Ooma customer service said the disconnecting issue is the Netgear C3000 denied ports .How can I fix this?The issue seems to have happened more in last 6 months .Have done resets but still disconnect...
Jul 06, 2021Guru - Experienced User
do any other devices have issues?
What actual problem are you running into?
How did they determine it was the router causing the issue?
- KingquakeJul 06, 2021Aspirant
Hi plemans,Just have Ooma and a laptop connected to the C3000.No issues with laptop .Comcast is service provider.Ooma had me run a diagnostic report and it showed about 30 denied ports and I was told to contact Netgear.
- plemansJul 07, 2021Guru - Experienced User
some ooma's have an their own integrated dhcp server.
Have you tried putting the ooma's IP address into the netgears DMZ
- KingquakeJul 07, 2021Aspirant
Your solution is probably beyond my computer skills. I had to look up dhcp and DMZ..Do I need to download the Nighthawk app to add The Ooma address?Thanks
