Questman99
Jan 08, 2022Follower
C37000 N600
How do you change the password on the NETGEAR 3700 Router ?
Jan 08, 2022Guru - Experienced User
which one?
Login password?
https://kb.netgear.com/20026/How-do-I-change-the-admin-password-on-my-NETGEAR-router
or ssid password?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
