vikashummer
Jul 19, 2021Aspirant
C6220 Router Modem having issues with allowing new devices to connect
When a newe user/device tries to connect to the WIFI, they get an error saying that the password is incorrect with several attempts. Very frustrating issue. Need to fix this.
Jul 19, 2021Guru - Experienced User
Is it incorrect?
Have you went in and changed the ssid/password?
make sure to avoid special characters/spaces.
vikashummer
Yes, i havent changed anything i verified on the console side. I have numbers as password, but i dont see that being an issue. i was initially able to gain access.
- plemansJul 19, 2021Guru - Experienced User
Have you tried going in and changing it?
then on your devices "forgetting" the network and reconnecting with the new password/ssid?
- vikashummerJul 19, 2021AspirantI havent tried changing the password since my main devices are connected already.
