Raehm
Jan 17, 2021Follower
C6250 router login problem
I bought this as a "remanufactured" unit, where the original router login un and pw were not erased. How do I access the router control panel www.routerlogin.net (192.0168.0.1) to update the un and...
- Jan 17, 2021
I would start fresh to ensure it was fully erased.
Push and hold reset for 7-15 seconds while its powered on.
that should get you back to the defaults
default login: admin
default password: password
you can also try access it at 192.168.100.1 (default modem ip address)
Jan 17, 2021Guru - Experienced User
