Clauram
Apr 14, 2021Follower
C6300 Can’t access routerlogin.net
Hi,    I need to update my wifi password which I was able to do through routerlogin.net previously but the website doesn’t seem to exist and the net gear pages throw me into a loop with no actual solu...
antinode
Apr 14, 2021Guru
> [...] the website doesn't seem to exist [...]
"seem"?
> [...] the net gear pages throw me into a loop with no actual solution.
I have no idea what that means.
   None of that is a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] the net gear website that it continues to direct me to. [...]
Should I be able to guess what that might be?
Have you tried "192.168.0.1" or "192.168.100.1"? Or the obvious?:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read?
- sato-yuichi-887Apr 14, 2021TutorIt's quite hilarious that the likes of you could be considered a "guru" around here. Low standards are a plague to every community. A monkey could take your place in this forum, and no one would notice the difference. > "seem"? Do you have trouble understanding basic English words? I'd teach you how to use a dictionary if you were capable of it. > I have no idea what that means. Well, OP did say that the "Netgear pages" threw them into a loop. A person with average reasoning skills would deduce that OP tried looking through some online articles and couldn't find their answer. But I think average reasoning skills are a bit too much to expect from you. > Should I be able to guess what that might be? You seem like you couldn't "guess" what 2+2 is. > None of that is a useful problem description. It does not say what
 descriptions or interpretations.Oh look, even you can occasionally give some useful advice. I guess even crap has some value. Your response would've been more concise if you left out the snarky, condescending comments. But who am I kidding? People like you (the products of lazy parenting) love to hear yourselves talk. The reason is that no one with self-respect would listen to you any more than they need to, unless they were insulting you, which must happen often. - antinodeApr 14, 2021Guru> [...] A monkey could take your place in this forum, and no one would
 > notice the difference. [...]Are you volunteering? - sato-yuichi-887Apr 15, 2021Tutor
 antinode wrote:Are you volunteering? Am I volunteering to replace you with a monkey? I'm not sure if that would be a fair trade for the monkey community. We get one of them, but all they get is you. It seems like trade-up for us and a trade-down for them.
